Just moved into my new house, and spent an age trying to suss out how the heating works.
I have a Worcester 240 combi boiler, age unknown. There is no wall thermostat anywhere, and none of the radiators have thermostat valves. This means the only method of controlling the temperature is via the dial on the front of the boiler (which I am told is used to set the temperature of the water as it leaves the boiler.)
This doesn't seem very efficient, or effective.
My long term plan is to upgrade the radiators, at which time it makes sense to fit thermostatic valves. In the mean time I would like to add a simple wall mounted room thermostat to help regulate the temperature throughout the house.
My problem is that I don't know where on the boiler to wire it into.
Any ideas?
Thanks in advance...
PS - Even if I raise the pressure manually it always settles back to 0.6 bar. I was advised this meant there was a problem, as it should never drop below 1. Is this true?
Any ideas?
