"i always thought the blade came down at the front to h
30 Sep 2006
Cambridgeshire
Just a quick question
table saw blade spins which way ??? :eek:
hope thie is not a realy daft question
:oops:
marty
depends which side you stand
but i think it spins towards you
Stand on the left hand side of the machine, and the blade spins clockwise,
and the teeth cut downwards at the front.
agree with the above, if the blade snatches the workpiece, it is flicked away from the user.
unless it travels past 180 degrees that is. :eek: :D
the teeth always pull the work towards the baseplate/table at the feed in point whether its a jigsaw a circular saw tablesaw chopsaw with the odd exception like worktop down cut blades in a jigsaw
http://www.screwfix.com/sfd/i/cat/pdfs/11/p4754811.pdf
even if you installed the blade on backwards it will still push the work onto the table at the front as it burns/rips it way through the workpeice
if the blade is comming up at the front its not only wrong its dangerous :rolleyes:
normally a bloody big arrow on the machine to give a clue
