J
jashton
hi. Can someone please list the order in which things happen when an Ideal Classic FF380 fires up. For one, I'm just curious and two I'm trying to diagnose likely cause of mine not igniting. I've had the fan replaced and while that appeared to fix the issue at the time I think it was just lucky timing with what has become a more regular fault. I need to get an engineer back out to take a look but I'd like to know a bit more about what might be wrong
When the call for heat is made the circulation pump runs up ok but the fan doesn't start and I hear no ignition clicks. If I give the boiler a hefty thump I hear the fan start and then everything fires up. It's requiring much more regular whacking though, so the problem is getting worse.
Could it be the gas valve solenoid? Seems they are fairly common faults after fan failures. I would assume that if the valve isn't opening to light the pilot (?) then the fan won't try to run and if that doesn't run then the APS won't allow the main burner to light. Is that the general sequence of events?
