Well from this latest description, which is different from your previous one, I would not rush into swapping the pcb yet.
The only moving part in the top of the boiler is then fan, but I would expect the boiler to fault with an L or H code if that was faulty.
Are you sure the boiler and system are actually full of water?
I would also be checking all your external controls are ok and haven't been damaged by the electric outage.
To eliminate these turn off the switched fuse to the boiler, remove the bottom boiler panel, 2 screws, then pull ot the wiring connector. Link L1 & L2 together, replace, apart from bottom panel, switch on and test again.
Post what happens.
If it works ok then it will be a control problem.
