Hi folks,
First of all I must apologise for not really having a clue, I'm trying to do as much research as possible, but due to being really busy with other stuff - I'm not taking a lot of it in.
Our 20 year old house has always had an absolutely terrible layout, the kitchen being a prime example of this - cupboards and appliances are scattered randomly and unnattractively all over the place - it's neither pleasing on the eye or particularly functional...
...because of this I'd like to move things around and create this "working triangle" I've heard of between the appliances. Most of this simply involves removing and relocating/replacing cupboards - something I can do fairly easily myself.
The only thing I'm stuck with is relocating the fridge freezer. Theres a spare wall socket where I'd like to locate it to, but the socket is not the same as the one it's currently plugged into (which I believe is called an RCD - but I stand to be corrected) the current one has a lower socket and fused plate with switch higher up on the wall.
If I'm correct (As ever I stand to be corrected) then the reason for this special kind of socket is to protect the occupants by breaking the circuit in the event of the fridge freezer becoming faulty?
As I'm not planning any other building or electrical work other than a simple swap around of cabinets, bit of re-tiling etc - I'm wondering whether I can get away with using a standard socket for the fridge freezer if I used a plug in rcd circuit breaker between the standard wall socket and the fridge freezers plug.
Hope this all makes, sense, thank you for taking the time to read.
