That was a cold water cistern connected to a open vented cylinder
The fault was the thermostat on an electric immersion heater failed to open and the water in the cylinder was boiling over into the tank in the loft
I was doing some work recently in a house where the unvented cylinder had popped and the side split open, emptying it's contents through the ceiling of the dining room. From what the customer was saying, the 2 port valve actuator broke and stuck open, and the pressure relief valve was jammed due to corrosion.
Cylinder had never been serviced in the 9 years it had been installed...
the specifications for the plastic tanks have now been upgraded to ensure they can take boiling water for a short time
another similar fault
What happened to the 3rd line of defence??Don't forget that woman that died too. All of these deaths were from directly heated cylinders though. I was doing some work recently in a house where the unvented cylinder had popped and the side split open, emptying it's contents through the ceiling of the dining room. From what the customer was saying, the 2 port valve actuator broke and stuck open, and the pressure relief valve was jammed due to corrosion. Cylinder had never been serviced in the 9 years it had been installed...
No idea, I was there looking at some lights...What happened to the 3rd line of defence??![]()
Open safety vent pipe should discharge to drain , most commercial installations have adopted this practice..
Do your own searching.Would like to see that change documented? Perhaps @bernardgreen can rustle something up from Google
How is a water resistant base going to help?
Eh??Open safety vent pipe should discharge to drain , most commercial installations have adopted this practice..
Did you do all your domestics thusly though?
with its 7 point safety system.
What are these 7 points ? safety devices such as pressure relief valves, if one fails will one or more of the other six ensure the cylinder cannot "go critical" ( as being in danger of bursting )
