I want to replace the single switch in my lounge with a dimmer. if i copy the way the original switch was wired it will not work.
i have two thick grey wires to work with - one with 2 red and 1 black wires, and the other 2 black one red. The earth wire is screwed into the switch housing.
Out of the two dimmers in B&Q It was a main dimmer switch i was advised to buy - it has 3 holes at the top which are L1 L2 and ~ , the existing switch has two holes at the top and one at the bottom, one red wire is in the top left hole, one red wire is in the hole at the bottom, 3 black wires are all screwed together in a plastic bit completely seperate from the light switch.
Any ideas?
Any ideas?
