- Joined
- 5 Jan 2020
- Messages
- 15
- Reaction score
- 0
- Country
Hi
I finally got around to upgrading the firmware on my Premier Elite 24 from V1 to V5, this seems to have gone OK.
I then tried connecting the Smartcom. The instructions say 4 wired connector to COM1 2 wired connector to COM2 but when I connected them this way there was no power to the Smartcom. I tried the 2 wired connector on COM1 and the 4 wired connector on COM2 and it lit up. I have selected ComIP for COM1 and Smartcom for COM2, the opposite way to the instructions, should this be OK?
I have connected the Smartcom via ethernet cable and the light is solid, however there is no activity at all from the cloud LED, I assume this means it's not connecting to the Texecom cloud. When I try and enable the Connect App from the keypad, it errors with Incorrect config CALL terminated.
There is a COM2400 connected which I have tried to disable in Wintex but it is highly likely tat I've not done that right and I'm hoping that it's one of these settings that is causing the Smartcom not to connect.
I think I need to go back a few stages and reset the panel to just after I upgraded the firmware start with the removal of the COM2400. Please could someone tell me the correct settings to remove a COM2400 from the system. I'll then do this and have another go at adding the Smartcom.
Any assistance greatly approeciated.
