Interesting reason for not using an extension lead with Plug-in Solar
Eric's scenario was specific to multi-socket extension leads, not extensions in general.
Thank you, that is an important point.
In real terms, I don't think I would be testing the pins of the plug, so even if the remained live for 5 minutes, it would not be a problem for me.
But the "and others" added to a competent person when compared with a skilled person, was a question asked with the BS 7671 exam up to 2008, and we have to look at those who don't expect anything to be sold which could be dangerous even where they do unreasonable things.
I know, but all extension cables are prohibited, therefore, it's a moot point. A theoretical scenario of what could happen if someone ignored the instructions/regulations, nothing more.
Not sure I see that, though. Do you mean a crossover in the sense of Pin 1 to Pin 2, and Pin 2 to Pin 1? When makers of XLR cables buy in a reel of cable, does the jacket have arrows on it so they know which way to use it?
It is a thing, some 2 core screened cable is made like this:
earth at the top hot & cold below, particularly FST cable (Foil Screened Twin) such as Belden 9501 etc.
Superimposed on an XLR can be a nice match with the hot and cold coinciding with the correct pins:
Or on the wrong end they may need to be crossed over, here shown with hot and cold wires coinciding with the wrong pins:
It is a thing, some 2 core screened cable is made like this:View attachment 423666earth at the top hot & cold below, particularly FST cable (Foil Screened Twin) such as Belden 9501 etc.
Superimposed on an XLR can be a nice match with the hot and cold coinciding with the correct pins: View attachment 423667
Or they may need to be crossed over, here shown with hot and cold wires coinciding with the wrong pins: View attachment 423668
So does that mean if I take a length of such cable, I can only attach an XLR connector to one end, as at the other end the cores will be in the wrong positions?
Or on the wrong end they may need to be crossed over, here shown with hot and cold wires coinciding with the wrong pins: View attachment 423668
However when this popular method is used, and as an Ex BBC engineer that particular consultant insisted on it:
It really makes no difference.
No! It just means there will be a physical twist within the connector.
No, it just means that instead of the cores lining up nicely with the pins, they have to be physically crossed to reach the right pins.
One way round will be slightly easier, the other will also work, but needs a little more work. It's very marginal with a 3-pin XLR and a single screened pair, but with more pins, thicker cable, and so on, it can make a noticeable difference. Note that XLR connectors are very spacious compared to some others. In the past I've wired 8 pin mini DIN connectors (used to be used for Mac serial ports), there really is not a lot of space in those, so differences in how the cores align can make a difference.
No! It just means there will be a physical twist within the connector.View attachment 423673
That's it, but as above, with the generous space in an XLR connector, it's a trivial difference.
However, if you are terminating lots of cables, it does affect your rhythm if there are differences. You get into a flow if they are all the same, that breaks a little if they vary. I notice this with 4 pair network cables.
I once had the task of terminating four 218 pin connectors, that's a plug and a socket each end of a pair of cables - specific connectors matched to the cables.
Unfortunately the cables had been run from one end rather than one from each end and no chance of turning one round. The connectors had to be cut and welded into a sleeve to extend it, something like this:
Originally it was around 200mm long and ended at arround 500mm.
So if the instructions are clear, if the instructions are followed, if nobody conspires to interpret instructions to be conived to be seen to meet the words but not the meaning, then all is good!
Hmmm , does that ever happen in real life situations???
Yet the extension cable known as "The Widow Maker" still exists here and there!
Erics inertia and back EMF situation reminded me of something I came across a few years back.
Legend was this small engineering firm (I worked for them for a couple of years) expressed and interest and requested a demonstration of a lapping machine.
A lapping machine is basically a large round cast iron table slowly revolving with components on the top and a large wheel layed on them to be a pressure plate, during the few hours rotation a coolant containing super fine abrisive dust was circulated around the table - result - a super fine finished form of grinding/honing/lapping of components.
Anyway the Technical Salesman chappy arrives on site with the machine, sets it up for a demonstration for directors and technical bods of the small firm in attendance.
The firms directors then took this salesman out to a splendid lunch in appreaciation of his demo - whilst they were all at the extended lunch the tech folk of the small firm partially stripped down the machine then rebuilt it in order to see how exactly it worked (all of the principles and dimensions etc).
"Surprisingly" they did not buy any machines but what they did do a few months later was to manufacture there own machines and have them sold via their "Sole Distributor".
Bit naughty heh?
Anyway, one problem they did have to overcome with their prototypes before production was inertia.
The drive motor assembly was a small motor at high speed running a worm gear or two to get the finished speed of the lapping table to rotate slowly.
The drive motor run down time on the worm was too slow resulting in a crash bang wollop of the gear housing assembly stripping gear teeth out.
Eventually by calclations and trial and error came up with a flywheel on the motor with suficient mass to match the natural slow down of the lapping table.
The run on of the machine was quite a time after the stop button was pressed, not instant by any means.
I was expecting a different tale there.
Slightly related, my late dad had a story of going to a site (joinery workshop) where they sometimes struggled to start one machine. It turned out they were missing one phase, but with multiple machines running, generated it internally. All was fine for an unknown length of time, except for one machine that needed a bit more "oomph" from the missing phase - so wouldn't start if there weren't enough other machines running.
