Hi all,
I would really appreciate some help if possible.
I have just had the above boiler fitted and I am finding that at full flow, the hot water only gets warm.
I told my installer about this and his solution was to not turn the taps on full! Needless to say, I wasn't impressed with his answer.
The flow from my cold tap seems to be quite high at about 20 l/min but I don't know what my water pressure is.
I have tried slowing the flow using the mains stop tap and this does indeed solve the problem if I slow the flow down to about 8 l/min.
Is there a way to reduce the flow of water through the boiler without affecting the cold water too by using the stop tap?
Should I even be having this problem?
Any advice would be greatly appreciated. I am disappointed to be having this problem on a brand new boiler.
Thanks for your assistance.
