    Dismiss Notice
Intergas HRE 28/24 Hot Water Only Warm
Discussion in 'Plumbing and Central Heating' started by timbeam, 1 Jan 2016.
  1. simond
    simond
    26 Oct 2004
    5,232
    Thanks Received:
    465
    Surrey
    Country:
    Intergas a Rolls Royce? That's funny. Did you look at it on the wall, even the casing is plastic.
    It's a simply a budget Dutch boiler. Think of it more like a Volvo 3 series.
  2. Sponsored Links
  3. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,034
    Thanks Received:
    9,420
    Hertfordshire & London
    Country:
    As opposed to a Poogeut which is a good approximation of Wooshitter Botch :D
    • Like Like x 2
  4. timbeam
    timbeam
    28 Feb 2004
    28
    Thanks Received:
    Country:
    I did say COMPARED to the Ideal Isar ;)
  5. timbeam
    timbeam
    28 Feb 2004
    28
    Thanks Received:
    Country:
    Thanks Razor, that's kind of what I would've expected.
    So, it's a better idea to reduce the flow at the boiler then rather than the stop tap. Is it going to be best to go with Dan's original idea of a flow restrictor then? Can someone point me in the right direction of where to get one please? Are the flow rates fixed in the restrictors or can they be adjusted?
    Thanks again!
  6. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,034
    Thanks Received:
    9,420
    Country:
    • Thanks Thanks x 1
  7. Agile
    Agile
    26 Jun 2004
    63,985
    Thanks Received:
    4,583
    London
    Country:
    Before you go fitting restrictors just open stopcock fully and reduce flow at inlet tap to boiler. Set to a hot water out flow rate of about 10 litres per minute.
    Then see how you find that and if the blue tap give you any noise problems.
    Those restrictors are fixed flow rate.
    Tony
    • Thanks Thanks x 1
  8. Razor900
    Razor900
    16 Nov 2007
    5,637
    Thanks Received:
    2,149
    Northamptonshire
    Country:
    Erm have you ever actually seen one??
    I think you'll find it's metal (y)
    Kind of puts your remarks into perspective doesn't it??
    Especially compared to your fave Worcesters which have all the plastic INSIDE the boiler ;)
    • Like Like x 3
  9. simond
    simond
    26 Oct 2004
    5,232
    Thanks Received:
    465
    Surrey
    Country:
    Last one I saw had a plastic front cover.
    It had a Wilo pump.
    The expansion vessel was an afterthought.
    Have they improved them then since the last ones I saw at EcoBuild and in the merchants?
    PS: My fave boiler was the Kidd VHE
  10. Sponsored Links
  11. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,034
    Thanks Received:
    9,420
    Country:
    The front and back have always been metal.
    The top plate and bottom tray is plastic.
    Much better than making the working components of of recycled v tech toys.
    • Like Like x 1
  12. Razor900
    Razor900
    16 Nov 2007
    5,637
    Thanks Received:
    2,149
    Northamptonshire
    Country:
    Hang on though Dan, it might have been one of the display ones in the merchants with the see through plastic cover ;)
  13. Dan Robinson
    Dan Robinson
    1 Jul 2007
    56,034
    Thanks Received:
    9,420
    Country:
    Can I get one of those for mine? :D
  14. Biggles..
    Biggles..
    19 Feb 2006
    29,926
    Thanks Received:
    9,102
    Country:
    @simond
    I see that the budget didn't stretch to an inbuilt flow restrictor?
    Only knows what the money went on as it wasnt on the look, marketing, service, fan, gas valve, pump, pcb??
    Should have saved a quid by not fitting that LWPS they don't need.
    • Like Like x 1
  15. Razor900
    Razor900
    16 Nov 2007
    5,637
    Thanks Received:
    2,149
    Northamptonshire
    Country:
    The 24/18 has a built in flow restrictor perhaps the rest of the range should just be commissioned properly - like every other combi on the market :)
  16. mcmoby69
    mcmoby69
    19 Jun 2011
    6,564
    Thanks Received:
    2,214
    Lancashire
    Country:
    there is a good chance that there is some 22mm pipework still present when the cylinder was removed and the isar installed. gas rates and working pressure need checking too, as mentioned before.
    if you look at the benchmark section of your boiler manual, it should be filled in and signed by your installer (and yourself) gas rates and temperature measurements, flow rates etc.
    if not you need to speak to him again.
  17. Agile
    Agile
    26 Jun 2004
    63,985
    Thanks Received:
    4,583
    London
    Country:
    I am not sure about Intergas but most boiler makers will not do warranty repairs on any boiler where the Benchmark Certificate has not been completed.
    In fact Gas Safe consider them as At Risk because the have not been commissioned ! That means they should be turned off and not used!
    Tony
Loading...
Share This Page
