    Dismiss Notice
Intergas HRE 28/24 Hot Water Only Warm
Discussion in 'Plumbing and Central Heating' started by timbeam, 1 Jan 2016.
  1. timbeam
    timbeam
    28 Feb 2004
    28
    Thanks Received:
    Country:
    Yep, that is all filled in (I assume) correctly.
    I can provide this info if it will be of any help in this situation. :)
    Thanks.
    EDIT: Just to update. I tried adjusting the cold flow rate using the blue valve under the boiler but it was virtually impossible to get the flow rate to 10 lpm. It was either a dribble or too fast. Also, the noise was unbearable! :(
    I have left the stop tap controlling the flow for now. Hot and cold are both at about 10 lpm.
  2. Sponsored Links
  3. simond
    simond
    26 Oct 2004
    5,232
    Thanks Received:
    465
    Surrey
    Country:
    Another statement that is hyperbole.
    One of the reasons Gas Engineers have a bad reputation with customers is a perceived draconian and self aggrandising desire to cut people off and write warning notices. Statements like this - that are simply untrue - only reinforce the myth.
  4. mcmoby69
    mcmoby69
    19 Jun 2011
    6,564
    Thanks Received:
    2,214
    Lancashire
    Country:
    would be interesting to see what the hot water flow rate figure is in your benchmark form and the temperature. also gas rates for hot water.
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
