Muggles, you recently kindly advised, in a different thread, about thermostatic programmer options - and introduced me to the Salus RT520RF to use with an Xclusive.
Having looked further I can see they also do a wired one (without the RF suffix)which is still Opentherm compatible but might possibly be a bit simpler? I like simple
I also see they go to the trouble of listing boilers that are compatible and, reassuringly, show the Intergas boilers listed there. A nice touch.
As you said before, the Salus 5 year warranty stands out from all the others.
So thanks again for adding to the sum of my (limited) knowledge.
I've looked at the Xclusive installation instructions and see that there is an onboard central heating programmer but I'm guessing people prefer to use the likes of the T3 or T4 or T6 or Salus RT 520 in preference to the ones built in to the boiler? I have the basic Honeywell CM 901 at present and like it very much.
One other thing I spotted was the preheat function (in its various settings). I get the principle of pre - warming the internals thus speeding up the production of hot water at the tap/shower - but wonder where the pre-heated water circulates? Is there some sort of small circuit around the HEX that the heated water runs through? I've never seen the topic raised before.
Am I right in thinking that the pre-heat function could easily be ignored on the grounds of wasting energy?
Am enjoying discovering facts about their range of boilers and feel quite optimistic.
Ta.
And still not...Just to ask if anything has moved on since the above discussion ... in particular re. controlling the time and room temperature whilst using a new Xclusive combi (which is envisaged but not actually installed as we speak).
I anticipate a boiler change in the not too distant future
I havent.If you've got wires in place, or are prepared to install them
There are no battery powered OpenTherm thermostats, no. The two-way flow of information between thermostat and boiler is pretty much constant with an OT stat, so it would burn through batteries far too quickly
I stand corrected, on both counts - I'd forgotten about the round stat!Not really correct, there is but we wouldn't support it with a different brand boiler. It's made and set up for our own boilers and is simply battery RF from stat to powered OT/ON/OFF receiver.
Not being an expert with evohome could not the round stat be bound to an OT bridge Muggles?
Do yous mean thisI stand corrected, on both counts - I'd forgotten about the round stat!
On my current boiler I have a knob on the front to control the DHW temperature.interestingly the DHW temperature selection can be disabled on the control leaving the boiler as the selector for DHW temperature further muddying the water between master (control) and slave (boiler) as defined in the OT specification.
