Hi All,
Currently my heating controls are in the garage with the boiler, after fitting a hive last week I was considering moving them into the airing cupboard and taking the following approach, has anyone got any glaring gotcha's I've perhaps not considered please.
System is Y Plan
Currently heating controls sit on a 3 Amp spur (need to check the fuse is actually 3 Amps) from the downstairs ring final.
Cables running from garage to airing cupboard are 4 Core + E and 2 Core + E. The wiring was a b*ggers muddle but I've sorted that out so the controller/valve/stat are all working how they should.
Vented Tank has an immersion heater, which is currently not in use (lets assume it's faulty)
Unvented system is due to be fitted in the coming weeks, not sure I want to fit an immersion at all to it, any compelling arguments as to why I would?
So the question.
Can I extend the 2.5 mm Radial that's being used for the Immersion through a 3 Amp fused spur in the airing cupboard to power the controller/pump/boiler/valve and stat?
Is it acceptable practise to share a power feed like this? The board currently has an 15 Amp cartridge protecting the feed for the immersion, this is going to be replaced by an RCBO at some point once OVO have fitted a double pole isolator.
If this is better placed in the Electrics section can a moderator move it please.
Cheers
Lee
System is Y Plan
So the question.
Cheers
Lee
