Is it possible to get a fused IP44 plug or socket?
21 Apr 2007
Edinburgh
Hi all
we're getting some building work done and part of that will include them running power to a garage. I'm not asking about any of the SWA/CU type questions - that'll be for the spark to figure out.
My question, though, is about the (I presume) IP44 socket I'll ask them to put in for my 150A (DC out) welder. The max input current is 28A so I guess I'll be asking them to put in a 32A IP44. All good, if that assessment is correct.
But what if, later on, I want to plug in a device with a 16A IP44 plug (say a smaller welder)? How do I "downrate" the connection to be max 16A? Can you get fused IP44 plugs?
Cheers
Scott
Just realised I'm a donkey and that 16A and 32A IP44 plugs are physically different :oops:
OK - here's a different question :D would a 32A to 16A adapter / lead come with a 16A fuse?
Just install a 32amp and 16amp socket on separate circuits next to each other, your covered all ways then, simples :)
Why :eek: ?
The one linked to has 2 MCBs in an enclosure - it would be reasonable to assume they've used 16A.
Use of stuffing glands isn't too clever, but if it just lies under a raised floor...
Maaaaaybe... dunno really. I don't actually have anything to plug into the 16A - I was just wondering what the options were if I woke up one day and decided I wanted to do it.
I guess the best answer is to run a 32A socket off a 32A MCB and a 16A one off a 16A MCB then.
Thanks all
I drilled my garage on the thick bits of the concrete. You can go about an inch deep which gives you a plenty good enough fixing without drilling right through the concrete.
Nuff said
Not spoken to him yet, BAS. Just sounding out whether it's realistic to ask for a 16A and a 32A, and it seems it is :D
They are indeed diffrent sizes, if not overly clear if just googling images! A 32 to 16amp lead ort to include a fuse/breaker but I have seen a lot that dont. I have seen a 125 A 5pin straight down to 16amp three pin unfused, but its not a very clever idea.
Indeed, expcially if the consumer unit is near by.
- Alternatively you could have a 32amp supply, to a 32amp socket, and the a fused spur of this to a 16amp socket if the CU is a long way and adding the second cable cost prohibative.
Daniel
I don't think I would be considering doing it this way, I would be looking at putting in a nice meaty submain from the CU and fitting a 'garage cu' then feed separate feeds from there for the 32a and 16a, can then do lights and 13a sockets on their own circuits. And if it was my house, I'd be putting RCBOs in too.
Last thing you want to do is travel a long way back to the CU to reset a breaker all geared up and covered in welding crud
I would be looking at putting in a nice meaty submain from the CU and fitting a 'garage cu' then feed separate feeds from there ....
Well this is also true, although to a certain extend it depends on the amount of welding the OP is planning to do, and the welder i question.
I have a small 160amp inverter mig, which will run very happly off a 13amp socket, and I use it in my garage for about an hour every third month if that, at which point you have to balance cost of install vs cost of conveinence.
Obviously if you want to put a 450amp twin wire welding robot in there and run it 24/7 with a targeted 95% uptime, in conjunction with other power tools, and a preheat over(?), the feed requirments change.
Daniel
Indeed, expcially if the consumer unit is near by. - Alternatively you could have a 32amp supply, to a 32amp socket, and the a fused spur of this to a 16amp socket if the CU is a long way and adding the second cable cost prohibative.
True, but if you wanted tio use an FCU for that spur, you'd obviously be limited to a 13A fuse. As others have said, the 'separate feeds' is certainly the nicer solution, although the spur might feel attractive if the sockets are distant from the CU.
Kind Regards, John
