I have a double socket which is definately a spur off the ring. I need to run power to a single light fitting. If i was to run 1.5mm from this spur socket to a 3 amp FCU then to the light is this classed as a spur off a spur.
If yes if i was to put a 13amp FCU before the socket , then run the 1.5mm cable from the socket to the a 3amp FCU to the light would this be ok.
