I haven't ordered the Chocboxes, luminaires or transformers yet, and before I do
I thought it best to check with you guys in case I need anything else to commence this job.
More importantly - is the following correct?
As I understand it, the best way to rig the lighting circuit up is in a star/parallel fashion.
Is the following correct for ELV IP65 light fittings?
With the ceiling rose cables now in the loft - I will exchange the blue + brown that fed the
old pendant light fitting with 1.5 T&E cable.
CHOCBOX NUMBER 1
This 'new' 1.5 cable goes to Chocbox number 1. (cable A)
Another 1.5 cable goes into Chocbox to feed Chocbox number 2 (and so on) - (cable B)
The connections inside Chocbox will be;
cable A and cable B (Live) are connected together
cable A and cable B (Neutral) are connected together
cable A and cable B (Earth) are connected together
From Chocbox to transformer will be 1.5 cable (live and neutral) connected respectively
to cable A and cable B
Transfer tails go straight to IP65 rated light fitting.
Just before the LAST light fitting, the connections to the Chocbox is NOT carried on,
but feeds the LAST transformer only.
i.e. there are no returning connections to be made.
If the cable lengths are kept to a reasonable length, then all halogen bulbs
should glow the same rate.
One other point - if the transformers do not have 'tails' what cable should I use?
I would appreciate if someone could confirm if this is correct OR point out where
I've gone wrong, or add any tips.
Many thanks in advance.
