Hi, I have been trying to install a dishwasher, to replace a faulty one. So, it should be just one out, one in. However, on the end of the cold water copper pipe, there is an isolation valve (I think it's called), with one of those little blue levers on it, which you turn to stop the water. When I screwed the new dishwasher flexible plastic pipe onto it, then turned the lever, water started to come out of the valve. I assume I need to change this then... never done this before, please could you tell me -
1. Shall I just buy another of these levered shut off valves, or is there something better?
2. When fitting the new one, shall I use PTFE on it, or am I right in thinking that it's a compression joint, so none should be used.
3. I assume that when I remove the old one, there will be an olive trapped tightly to the pipe, how do I get this off?
4. Are these valves prone to leaking?
5. Is it just a case of taking the old one off and fitting a new one, or do I need to prepare the copper pipe in some way?
I have a further issue in that I have no way in the house of turning the water supply off. I have to use the outside stop tap in the ground but this doesn't turn it off totally, so I shall have to change the valve with the water still dripping slightly.
Sorry to be a pain, plumbing is an art form, it has to be done right or it just fails!
Any help appreciated. Thank you.
