YEah go for the second one, are I've got the peglar ones at home, a red one for hot, blue for cold and yellow for gas, they look better and are real easy to open/close
Not sure if they are all like this, but mine are the non-restrictive (or similar) type.
Although they are only (in my case 22mm) the actually look much bigger meaning that the bore through the middle is larger than you'd expect. If you see what I mean.
