Maybe, but I suspect you're going to have to learn to live with them, not impossibly as 'the government' or, at least, probably a major component thereof.Certainly not. Reform are extremist grifters who serve only themselves.
HSS used to hire out the stuff to do itI didnt want to start WW3 lol, just thought it would be nice and easy for a diyer without a pipe vice or stocks and dies..![]()
It can be hired from most hire places, but the hassle and cost is not really justified if one just has one or two joints to do.HSS used to hire out the stuff to do it
Let's be honest here, conduit work isn't something the average DIYer can just do. It takes a certain amount of practice and wasted tube, especially if bends are involved. I don't claim to be an expert by any means but the bits I have done will stand up to some scrutinity, I'm sure not perfect by some peoples standards but I think OK and certainly better than some. The first jobs done with split tube, one of which I still see on a occasional basis and hate the slope caused by clearing an obstruction. I'm very aware of the difference of my results between the first and the last of threaded and bent tube. Not forgetting the jobs I did in 1970's & 80's with a type similar to Conlock, 3/8" steel, the biggest pain with it being the locking screw was on one side and frequently poor accessibilty when against a corner or ceiling, or 1/4" (later 8mm) aluminium which was also available with clamp type fittings (same style as split tube) but much bulkier.It can be hired from most hire places, but the hassle and cost is not really justified if one just has one or two joints to do.HSS used to hire out the stuff to do it
As an apprentice I had to make 10 nipples on two inch conduit, could hardly turn the stocks, can still smell the tallowI remember doing running couplers....!
im sure when push fit first came out there was no grubscrew, just a tab inside riveted on that put pressure on the conduitLet's be honest here, conduit work isn't something the average DIYer can just do. It takes a certain amount of practice and wasted tube, especially if bends are involved. I don't claim to be an expert by any means but the bits I have done will stand up to some scrutinity, I'm sure not perfect by some peoples standards but I think OK and certainly better than some. The first jobs done with split tube, one of which I still see on a occasional basis and hate the slope caused by clearing an obstruction. I'm very aware of the difference of my results between the first and the last of threaded and bent tube. Not forgetting the jobs I did in 1970's & 80's with a type similar to Conlock, 3/8" steel, the biggest pain with it being the locking screw was on one side and frequently poor accessibilty when against a corner or ceiling, or 1/4" (later 8mm) aluminium which was also available with clamp type fittings (same style as split tube) but much bulkier.
However I have to say that throughout my working life I have been around tube work (even if not directly involved) so I had an insight into it's installation which the average DIYer will not have the same advantage.
At college in the eighties, I had to do various bits of galv conduit with MICC cable attached to it and accessories, just as an exercise. I don't think I've ever needed to do anything quite like that again but it was great practice.
Oh crikey yes, I'd completely forgotten that stuff.im sure when push fit first came out there was no grubscrew, just a tab inside riveted on that put pressure on the conduit
You're not a fan then?Craplock more like.
Joints which are 'fixed' together by a single grub screw, not waterproof, when used outside the conduit will fill with water, the screw points will gouge into the galvanised coating to ensure corrosion.
It's overpriced junk which was created to deskill the industry so that ham-fisted imported labourer types who will work for less than minimum wage can be let loose on 'installing' electrical conduit.
In my view Conlock does not replace the real thing but it has some very good benefits. One of which is avoiding running couplers.You're not a fan then?![]()
The same is true of a lot of DIY tasks, it takes time to figure out what works for you and what doesn't, and develop your technique.Let's be honest here, conduit work isn't something the average DIYer can just do.
Indeed - but in the present context, it goes somewhat beyond that when specific kit is required and it's use would be only extremely 'occasional'.The same is true of a lot of DIY tasks, it takes time to figure out what works for you and what doesn't, and develop your technique.
