You did add heat transfer paste to the temp sensor point didn't you?
Hi Tony,
No, i didn't but asked the plumber to do it when he serviced the boiler but had a look earlier and it's the same as I left it.
It's all a little academic at the moment as one of the wires connecting to the buld has come off so I need to order a replacement thermistor anyway but will need to know when I fit the new one.
thanks again,
Steve
For the avoidance of doubt the thermistor element is the toffee colour lump at the end of the uninsulated wires. This should be straight with the wires kept apart about 2-3 mm just like the excellent drawings in the MI.
The socket should be filled with heat transfer paste and the thermistor inserted into the filled socket in one movement.
I am not very impressed by your "plumber" if you asked him to add the paste and he did not or even mention it to you. He either did not touch it or did not even realise that the wires should be straight and not touching. Very much a plumber and not a boiler engineer I am afraid.
This is very much a problem in our industry. Gas boilers are all controlled by electronics and use electromechanical parts yet most people working on them have little understanding of how they work.
