There you go again, why did it boil yesterday and not today.
What was different in the boilers use, Did you have the heating on today and not yesterday for example.
I will have 50p on an almost completly blocked cold feed.
because there might be enough water in the system to let the rads heat but the boiler will soon start boiling if there is no gravity circulation when the hot water is run on its own,
it could be the blockage is letting enough water through to top up the water level when its switched off and then drops as the boiler is run, without being there I am guessing as much as you are.
But Picasso why should the boiler temp control system cause it to overheat?
Steve perhaps following Picasso's advice might be better than what your BIL intends to do. If his grasp of things was that good, then this thread would not be on page 4.
Get a magnet and place it at various points on the two pipes that put heat into the cylinder, starting at cylinder connection towards the tee and checking the tee as well
