Kitchen hood venting on party wall
12 Feb 2015
Surrey
My kitchen wall is at the boundary, actually it forms the boundary. Can I open a hole and vent over this boundary into the adjacent plot?
No, especially if there is someone living next door.
It is a trespass.
Nothing of yours should extend into the neighbouring land, no gutters, no fencing, no vents, nothing.
If your arrangement allows it and if it is a cavity wall you could vent through the cavity and then out in "your" space. I did this using 200mm solid vent pipe and it worked fine for over 15 years
Regards
Tet
Regards
Tet
The cavity is filled with rigid insulation, where would the greasy steam go, and would it not foul the insulation with grease deposits etc?
Edit: sorry, ignore me, I understand now.
I don't know about kitchen extractors, but gas boilers must exceed a specified distance of the boundary if pointing towards it. Ours was fitted just around this distance limit, but I moved it as I was ashamed of the steam billowing against next door, trapped under their soffit.
Our kitchen extractor pointed the same way. I also regretted this, I thought we were being bad neighbours but we sold up so it's someone else's problem now.
Don't be a dick. Vent on your land, within your land.
You can hide a duct inside, or on top of, your wall cabinets, towards the end wall
My neighbours' cooker and boiler both vent onto my land - a scruffy area that I've been meaning to fettle for 20+ years. I suppose a lot depends on how you use the area under the vents. When my new boiler was installed I was offered a visit from the Gas Safety chap. He spent ages here and, after a few gallons of tea, decided that the vent was too near to next door's boundary (by a few cm). He said that he had to report it to the installer but that I could simply ask my neighbour if they objected. They didn't, the installer rang to ask if I wanted the whole thing shifted - I didn't and, quite frankly, we've lived with it for over 5 years.
A kitchen extractor can vent upwards out of the roof, with a vent tile or witch's hat collar.
If that would be suitable for the location. It would then be close to the neighbour, but at least higher up and not firing directly at them.
I quite understand. One of my neighbours has a house where the part with the front door is recessed from both sides which project further. The boiler was installed in this recess, which fills with billowing steam in winter, especially when she turns on a hot tap, and when the heating starts up.
Another neighbour with a similar house had a sort of elephants trunk installed, which rises up to the roofline. Both houses were originally built with conventional balanced flue boilers, with no visible plume.
I took care to have my new boiler installed near a corner of the house, away from doors and windows, where the wind swirling round the corner dissipates any plume.
Doesn't the steam condence and run down?
I need to open a hole in the ceiling, through the loft, and downwards into the eaves - somehow. Very tight in there.
A vertical one is at risk of that. More common in bathrooms where they carry more steam and less hot air.
You can get insulated duct to reduce the risk.
It will be best if you turn on the fan as soon as you start cooking, to warm it up before the steam starts.
Horizontal ducts, provided they are the rigid tube, not convoluted flexible pipe, can be laid slightly sloping so that any condensation runs down and drips outside the house. The first vertical piece through the ceiling will be hottest and least prone to condensation.
I have a vertical extractor that I fitted in a bathroom ceiling. I fitted one of these on top of the ceiling...
It's basically a straight-through coupler with a little gutter around its inside edge that connects to the drainage pipe fitting.
I connected its drainage pipe to some plastic tubing (think it was toilet overflow from memory), and managed to sneak it through a hole I drilled in the fascia into the outside rainwater guttering. Nothing visible at all from the ground.
Then didn't fit any insulation at all. Just rigid smooth ducting. I agree, definitely avoid the flexible rubbish.
No issues at all. No idea whether it collects water, but I definitely don't get any dripping or other issues in the bathroom below.
