The cavity is filled with rigid insulation, where would the greasy steam go, and would it not foul the insulation with grease deposits etc?If your arrangement allows it and if it is a cavity wall you could vent through the cavity and then out in "your" space. I did this using 200mm solid vent pipe and it worked fine for over 15 years
Regards
Tet
I don't know about kitchen extractors, but gas boilers must exceed a specified distance of the boundary if pointing towards it. Ours was fitted just around this distance limit, but I moved it as I was ashamed of the steam billowing against next door, trapped under their soffit.
Doesn't the steam condence and run down?A kitchen extractor can vent upwards out of the roof, with a vent tile or witch's hat collar.
If that would be suitable for the location. It would then be close to the neighbour, but at least higher up and not firing directly at them.
I have a vertical extractor that I fitted in a bathroom ceiling. I fitted one of these on top of the ceiling...A vertical one is at risk of that. More common in bathrooms where they carry more steam and less hot air.
