Kitchen LED
21 Nov 2005
Yorkshire
I wish to replace my old under the unit lights ( bulbs 30w), with LEDs
Ive removed the units and chased out the original cable which is directly linked to the light switch on the wall and is 1.5mm.
I was going to place a socket above the units and use the same cable so as the lights can still be operated by the lights switch.
What type of socket should I fit. I dnt want to use plugged transformers but ones I can fit on top of the units and wire to the led and power source.
Any suggestions
30 Jun 2009
Londonderry
Have you chosen the lights you wish to install, that could dictate the method used?
Why would you prefer a socket other than the switch or even a switched fused connection unit?
It would not be a good idea to use a standard 13A socket, if you were to go down the socket route, but instead use a 5A socket-outlet and a 5A plug.
There are 5A plugs that can be fused but there some that cannot.
27 Aug 2003
London
Probably there is no neutral in that cable, so you can't put a socket on it.
http://www.diynot.com/wiki/Electrics:Lighting
11 Jan 2010
London
BAS is wrong. There should be a switched live , neutral and earth. I would use a 2amp plug and socket, smaller than a 5 amp. As presumably it is on the lighting circuit fused plugs are not required.
You don't use transformers for LEDs. Transformers give out AC. LEDs usually require DC and are run off special LED drivers.
22 Jun 2010
As Prentice Boy says, choose your lights first. You might end up with one that has a wall-wart type "transformer" which plugs directly into a socket rather than having an in-line "transformer", in which case you'll need the socket.
PJ
28 Jul 2006
Oxfordshire
Before we revert to Transformer Wars 3
The term "transformer" in the above responses has been used in its broadest sense (street talk, if you like).
ie: transformer - an electrical device by which alternating current of one voltage is changed to another voltage
Lets not complicate things by another in-depth session of pedantry. I thank you!
28 Jul 2006
Oxfordshire
Winston.
HOW DARE YOU DO THAT
You have altered what I stated, that is out of order.!!!!
The purpose of the quote facility is to highlight what another poster has already stated. It is not acceptable to change what I wrote.
I am happy to debate, elsewhere, how things have changed since William Stanley in 1885, but PLEASE, don't bring your anachronistic stupidity into every thread that includes the T word.
25 Jun 2012
What's a transformer with a rectifier which outputs DC called then winny?
