But it says on the pack it is a filler and gluecolorfill is a filler not a glue. The clue is in the name....
No, I managed to flatten the bumps with clamps for a few days and then filled. I feared clamping after filling would squeeze out excess that would set hard as I have to use wooden blocks with the clamps.Did you use the clamps recommended to hold it in place whilst the product cured?
Colorfil is c*ap that is my professional opinion. Wheras Bushboard Complete is both an Adhesive and Sealant and I use it and recommend it.
Colorfil cures in about 6 minutes from opening making it very stressful doing worktop joints and cost about £8.00 for 25gram tube, whereas BB Complete starts to cure at about 20 minutes and costs £30.00 290ml tube.
I fit fails again, buy colour match BB complete.
Its a Hybrid Adhesive and Sealant, I know it's not silicone based as I tried to seal the upstands with it, introduced soapy water for tooling created a nightmare for myself.So if not a silicone, is it a MS polymer?
I get what you are saying about Colorfil. I have only used it a few times but you have to remove any squeeze out using the solvent immediately.
The next time I will try the BB.
Thanks for the recommendation.
