We are having a new kitchen installed shortly. An electrician will be doing the wiring. We are going to have quite a few high current appliances. Oven, microwave, dryer, dish washer & washing machine as well as the usual low consumption devices like fridge/freezer etc. All of these appliances are built in. I don't know the rating of all the appliances yet, but I know that the oven is the type that can be plugged in so it must be under 13 amps.
The oven and microwave are together, so I'm thinking they could share a radial wired in 4mm on a 32amp mcb. The dryer and dishwasher are also together so they could also share a radial wired in 4mm on a 32amp mcb. That just leaves the washing machine as the only high current device and low current devices (like the extractor fan) which could run from the downstairs radial. The above bench sockets in the kitchen could also use the downstairs ring.
Does this seem a reasonable solution? There are two spare ways on the RCD side of the CU to support these new radials.
