I'm in the process of getting the nursery ready with my partner... I'm 35 weeks pregnant and on a budget so trying to install laminate flooring ourselves (my partner is doing the actual physical parts and I'm doing the calculations).
I was measuring up and I can only get 2 boards along a row and then there's a 6cm gap which means I'd have to cut a board to fit, but this would look ridiculous. We're unsure what the most efficient thing to do is? Do we try to stagger the boards by cutting them, so we have 4 different lengths to use (whole board, 2/3 board , 3/4 board, 1/2 board?)... not sure if I'll end up running out?! I have tried searching for a floor layout calculator with no luck
Any suggestions would be great, we are on a budget and can't really afford to get a professional in as baby stuff has been expensive.
Thank you for any advice.
