    Dismiss Notice
Large flat roof. Best covering options?
Discussion in 'Roofing and Guttering' started by Thepenetrator1, 24 Nov 2016.
  1. Thepenetrator1
    Thepenetrator1
    22 Jan 2013
    35
    Thanks Received:
    Leicester
    Country:
    Hi all,
    I’m having a flat roof on an extension I am building and the area is approximately 8m x 6m - 48m2 (not taking into account the skylights) please can anyone recommend a roofing system that’s suitable for large areas such as this.
    It will be visible from the upstairs windows but I understand it’s there to serve a purpose rather than look [pretty.
    I’ve looked at GRP & EPDM and yesterday I spoke to a chap who does torch on felt who was very helpful and also suggested asphalt.
    My main concern is the movement within the large area for the GRP and the fact it will be exposed to a lot of sun for the EPDM.
    The BCO also said I will need a metre run of stones at next doors side on the roof if I use rubber to stop the surface spread of flames.
    Everyone recommends their own systems so it’s a little difficult to find the right system for what I need.
    Anyone’s thoughts will be greatly appreciated.
    Thanks all.
  2. Sponsored Links
  3. Rufus Raintight
    Rufus Raintight
    25 Sep 2015
    39
    Thanks Received:
    11
    Yorkshire
    Country:
    Does the roof catch a lot of sun?
  4. ^woody^
    ^woody^
    3 Sep 2006
    30,026
    Thanks Received:
    3,908
    West Mids
    Country:
    You can use rubber (or plastic) without the stones, if you use the right make and the roof is properly detailed.
    Asphalt is for mult-storey car parks, but in reality any product will do. I tend to specify EPDM nowadays and beleive that it has the longest lifespan and is easiest to maintain. But compare prices from comparible qualified installers, and not any old Joe who can just happen to pick up whatever you want fro the merchants.
  5. ^woody^
    ^woody^
    3 Sep 2006
    30,026
    Thanks Received:
    3,908
    West Mids
    Country:
    It's in England. What do you think?
  6. hardmetalking
    hardmetalking
    2 Sep 2009
    260
    Thanks Received:
    33
    Cambridgeshire
    Country:
  7. Sponsored Links
  8. chappers
    chappers
    27 Aug 2004
    3,254
    Thanks Received:
    357
    Country:
    requires a bigger fall, minimum pitch 5 degrees, so over 500mm for the 6m length
  9. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,974
    Thanks Received:
    320
    Country:
    If you are doing it yourself, I definitely recommend EPDM (having done it myself).
    Cheers
    Richard
  10. hardmetalking
    hardmetalking
    2 Sep 2009
    260
    Thanks Received:
    33
    Cambridgeshire
    Country:
    Zinc requires a 3 degree fall not 5.
  11. chappers
    chappers
    27 Aug 2004
    3,254
    Thanks Received:
    357
    Country:
    yeah apologies bad memory by me knew it was five but was confusing my degrees with %. Either way a pretty big fall somewhere in the region of 300mm
  12. tomfe
    tomfe
    27 Aug 2014
    1,262
    Thanks Received:
    160
    Country:
    I've just done 120m2 in EPDM, not fun getting it up on the roof ~150kg.
    You can get flame retardant epdm.
    Single ply is, I think, the best(TPO/TPE), it's about twice as expensive than epdm for the materials but you can get fleeced backed which is very nice and stick on standing seam details.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
