Lead Pipe replacement
25 Jan 2019
Hello
I'm having a lead pipe replaced with 25 mm MDPE up to the stop cock
After the stop cock what is the best pipe to use.
I was thinking 25 mm MDPE has a large bending radius and something more flexible would be beneficial.
PEX?? 22 mm??
Yes, 22mm Pex or any other 22mm rolls of plastic pipe.
For tight bends use Bend Fittings.
MDPE typically isn't used inside properties.
Thanks tell80, thats what I wanted to know if MDPE was used after the stopcock
