light switch
How do you know it was not a false "negative"
It could be indicating that the conductor was not Live ( a negative reading ) when the conductor was in fact Live but you did not get a shock when you touched it.
DO NOT TRY THIS
It is possible to hold a bare Live wire and not receive an electric shock. To receive a shock there has to be two points of contact with the body. one Live and one Earth or Neutral.
Birds can safely perch on bare overhead cables at 11 kV
That is a valid question. On each occasion I was standing on the ground (ie earthed rather than on a rubber mat), on some of those occasions I did double check by using a multimeter.
Ultimately no tool is infallible, every tool has it's pros and cons. Electricians in the UK seem to put all their faith in "two pole testers", but a "two pole tester" won't tell you if *everything* is live including the earth terminal and the bloody box! A neon screwdriver will.
"A neon screwdriver may". As you say, no tool is infallible, and that includes neon screwdrivers.
If "everything" in the house is live, then it's quite likely that the capacitive coupling from the user's body to 'live things' will be greater than any capacitive coupling to true earth - in which case the neon screwdriver wouldn't indicate "live" any more than a 'two-pole tester' would.
Kind Regards, John
how did you know I was wasting my time faffing about with a neon screwdriver !! lol
Maybe you don’t realise this; but for an electrical item to work (such as a mains lamp) it needs two things a live supply, nominally 240volts, and a neutral.
Your neon screwdriver or magic wand device can help you with determining if there is a voltage, but it’s as useful as an ashtray on a motorcycle in checking that the neutral is in place and actually is at zero volts.
the neutral is half of the supply for a circuit and provides half of the problems when things don’t work.
A two probe voltage test device is what is needed.
Firstly, apologies if I have not replied to each individual thread. Can I start again? here's the back of the light switch.
It was the way you expressed yourself. If you'd been using a 2-pole meter of some sort you would have described what you found in more accurate detail. :)
As EFLI already suggested, have you tried putting both switch wires into the same terminal?
Are you certain all the wires at the ceiling rose are securely terminated?
Have you checked the actual lampholder? Are the connections ok?
Does the lampholder pins make contact with bulb?
