I had some house renovation work done a couple of years back and the electrician provided me new lighting in the dining room-to-be consisting of 6 low voltage down lights and a central single lighting point. Both lighting systems are controlled by a double dimmer switch in the room.
As this work was done prior to decoration and other work he left it so that the 6 down lights were working from the dimmer switch but the central light was what I thought an isolated (taped up) supply from the middle of the ceiling.
My assumption was when I was ready to fit the pendant light it would be a case of turning off the lighting supply , fitting the pendant and off we go. Seems what he left me was not so simple and what I have is the following:
4 cables from ceiling:
The 3 cables are connected via connector blocks as follows:
Any pointers as to how this works or was intended to be configured to supply the pendant light ?
1 x Twin & Earth cable (not connected) which is the unused switch cable (confirmed and tested)
2 x Twin & Earth white supply cables
1 x Twin & Earth grey cable which is the in use switch cable for down lights
The black wires from the 2 white cables (assumed supply) connected to the blue wire of the switch cable.
The red wires from the 2 white cables connected to the brown wire of the switch cable
