The 3 cables are connected via connector blocks as follows:
The black wires from the 2 white cables (assumed supply) connected to the blue wire of the switch cable.
The red wires from the 2 white cables connected to the brown wire of the switch cable
Any pointers as to how this works or was intended to be configured to supply the pendant light ?
Red wires should be your live loop in terminal block.
Black wires should be your neutral loop in terminal block.
Earth wires should be your earth loop in terminal block.
Assuming your dimmer has been wired as normal ie red in C and black(with red sleeve) in L1 then...
At the ceiling
Your switch (red) should be connected to the live loop terminal block- this will take the power down to your switch.
At the ceiling
Your switch wire black(with red sleeve) bringing the power up from the switch should be wired to the brown in the pendant. The returning blue wire from the pendeant should be wired to the neutral loop block. Any earth should be wired to the earth block.
Thank you Riveralt,
that made sense and was exactly the solution.
I should have mentioned that the earth is present and connected in all cases as the switch and lights are metal cased.
Based on above I tried this and it works:
