Lights in zone 1 of swimming pool
6 Jun 2008
London
If lights fall within zone 1 of a swimming pool they must be SELV. But,
if they are IPx2 or IPx5 rated and covered by a 30mA RCD is this also acceptable?
FFS. Do you have a copy of BS7671. If not, why are you installing equipment in a swimming pool?
Get yourself a copy and read it
In particular 702.410.3.4.1
It doesnt say "maybe"
There are no get out clauses . Here's an overview
Also 702.512.2 SPECIFIES external influences.
IPx2? Don't be stupid :rolleyes:
Having not yet done my 17th :confused: I just wanted to ask a quick question.
I know under the 16th you could not have a mains volt fan in zone 1 but an SELV fan was ok. Under the 17th, can you have a mains volt fan in zone one if it is protected by an RCD?
Shedi - you'll struggle to get your 2382 unless you do have a copy and can read....
BAS, i'm going from memory, I don't carry my regs with all the time, I have a life i suppose..... ;)
What do past posts have to do with it? And by the way, I'm not installing a thing in a swimming pool just simply a question.
Honestly, advice is what I want and what most people that come on here want, not a lecture of what i should and shouldn't do!
Doing one's job properly doesn't have any bearing on one's personal life. There's a time for work and a time for play, and you need to have the right hat on when you're commissioning any kind of electrical installation where there will be people, water and electricity in close proximity. Not having your regs with you just doesn't wash.
[sorry for the pun!]
