LIM entries in EIC for consumer unit replacement
26 Nov 2015
Hello, I've recently had a consumer unit replaced in a modern flat and have been issued with an Electrical Installation Certificate. In the schedule of test results, seven circuits have "LIM" recorded in both the Continuity (R1+R2) and maximum measured earth fault loop impedance (Zs) columns. 5 of these circuits serve kitchen appliances and the heating, and the electrician said the other two are not in use. My understanding is that LIM means the tests couldn't be done, but I've not been able to get the electrician to explain why, and they have just said that everything is fine. I'm wondering if it is OK to leave it like this, or should those test results be completed? Are there potential good reasons for there being LIM entries?
LIM is an entry in an EICR not an EIC, this house for example is split into main house and flat under the main house, and if I wanted to rent one out it would need an EICR, but circuits associated with the other, could be recorded as LIM.
Don't limitations have to be agreed with the customer and documented?
Anyway - seems like a lot of circuits for appliances - is it one per, and they are built in, and he can't get to the appliance ends of them to be able to test?
Yes agreed with the client. An agreement does not depend on the electrician agreeing and the client not agreeing
