Interesting.A year or two ago France radio decided they no longer wanted to broadcast on LW. But the Allouis transmitter on 162kHz also provided sync signals for railway station clocks throughout France. It was found the power could be substantially lowered without affecting the clocks. So that was done, the radio modulation turned off, and France radio no longer paid for it. It is still possible to tune in the silent carrier to this day.
My understanding is that a lot (most?) of the 'radio controlled clocks' in use in the UK use the time signals from Droitwich - so maybe something similar will happen here. If it did, I would imagine that if the much lower-powered transmission was enough to synch cheopo 'radio-controlled clocks', the same low-powered transmission would probably be able to successfully continue to provide the teleswitch service.
At least in the past, the Droitwich 198 kHz signal (the frequency of which is controlled by an atomic clock) was also used as a 'frequency standard'. If that's still the case, that's something else that might need to continue with a much lower-powered transmitter.
Kind Regards, John
