Hi all
I have a a boiler with separate hot water tank, and a water tank in loft.. had no issue with hot water pressure for years,
Then kitchen tap (down stairs) lost hot water pressure to a very slow trickle, I put up with it for a few months but now I have issues upstairs whereby the shower will not work
( I have an electric pump supplying the shower pressure but it keeps cutting out if I try to have any heat coming through it, I suppose because the pump isn't getting the hot water feed it needs and cuts out so as to not run dry and break)
I have taken the the top fitting out of the hot water tank to check for blockage which is ok, other hot taps are ok ( not high press but ok)
My next plan is to disconnect every hot pipe i can get to in order to try and find and remove any blockage... but a plumber I am not... any advice would be very welcome
