- Joined
- 27 Jan 2008
- Messages
- 27,419
- Reaction score
- 3,310
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
An inductive load will cause more arcing on the contacts than a resistive load, however for these sockets also an inductive load could produce RF which could also effect the socket.
Things have improved, but around 10 years ago we had a dog, and I had to take it for an evening walk, so while on the walk I would chat to my radio friends on the local repeater, I was only using 5W and the radio was tested and it had a very clean output, but it was like Blackpool illuminations watching all the security lights flashing on and off as that very low power activated them.
My father lived across from a police house, before the police radios went digital he could hear them talking on his electronic organs speakers.
If the light wave devices interfere with ham radios, then the reverse is likely also true, now the light wave device uses milliwatts, but the radio ham is allowed 400 watt. If the ham is using speech then likely it will not affect the light wave device, but hams also use digital communications, so it is very likely that be it emergency services, ham radio, or simple taxi that at some time radio waves will swamp the device and cause a malfunction.
Because they work today, does not mean they will work tomorrow. We are swamping our houses with radio waves, to expect they will not interfere with each other is to bury ones head in the sand.
To use a device which you can unplug and stop using if there is a problem is OK, but to use devices which are fixed into the fabric of the house is asking for problems. Looking at immersion heater time switches they are also rated 13A resistive, but for an inductive load rated around 5A so it would seem likely the same with the socket.
