The standard for a UK plug, and a UK socket, was required to be adequate for a 3kW load because, when it was introduced, that was the biggest load that was expected in a UK home (it was at the time a 3-bar electric fire).
At the time, it was not expected that you would use two such loads in the same room, never mind plugged into one outlet, though it was anticipated that you might want a trivial load such as a table-lamp at the same time, and double sockets are fine for two light loads.
We now have many more 3kW appliances, such as dishwashers and washing machines, though with the introduction of central heating and better insulation, 3kW portable heaters are less common. However the standard has not been altered. You should not plug two 3kW appliances into a double, because this will exceed its rating if used at the same time. A washer and a tumble drier together are common causes.
As Securespark mentions, some manufacturers design their sockets to surpass the British Standard. These may not be the cheapest.
