I used to do it with a piece of paper and a pencil.
I suppose if you wanted to splash out on professional tools, you could buy a calculator and a tape-measure.
I'm just wondering if there is a relatively easy way to measure the real value rather than calculate the theoretical value.
Why ask then?I'm familiar with the theory
Yes, looking up the tables and calculating the number is the theory, but it would be nice to see if the theory comes close to the practice.
IR camera will only tell you the temperature and you'd be able to see where the cold spots are, but not much use for a practical U value.
I reckon I could do it with a small heater so I knew what the power input was, thermometer inside, one outside to measure the difference, a still, dry day so the external temperature is relatively constant, let the room heat to a steady state so power in = power out then heat ...
Oh well, perhaps something to ponder over the weekend.
Yes, that is a clever 'out of the box' way of doing it.Or start with your gas bills, and work backwards.
