    Dismiss Notice
Metal Clad Sockets
Discussion in 'Electrics UK' started by bennyboy1985, 10 Mar 2017.
  1. bennyboy1985
    bennyboy1985
    28 Jul 2014
    2
    Thanks Received:
    Essex
    Country:
    Hi
    Just a quick question... i have surface mount metal clad sockets in my garage. My question is...
    Is there anywhere you can buy just the metal clad sockets? not the socket and back box combo.
    The following is a link to what i have already installed...
    http://www.screwfix.com/p/mk-13a-2-gang-dp-switched-plug-socket-metal-clad/49437
    I want to change a couple of socket fronts to the type with USB connectors on...
    http://www.screwfix.com/p/13a-2-gan...lad-switched-socket-2-1a-2g-usb-charger/8009j
    Any help is welcomed :D
  2. Sponsored Links
  3. JohnD
    JohnD
    15 Nov 2005
    74,268
    Thanks Received:
    4,290
    Crossgates, Europe
    Country:
    Cook Islands
    I can sell you the socket fronts for £25 each plus P&P.
    This covers my cost of buying the assemblies and removing the boxes.
    When you later discover that you need the boxes because, being a different make, the old ones do not quite fit, I can sell them to you at £10 each plus P&P.
    • Like Like x 3
  4. flameport
    flameport
    10 Mar 2007
    9,933
    Thanks Received:
    1,991
    Poole, Dorset
    Country:
    There isn't and even if you could it would be pointless - they are designed as a single unit.
    Metal clad sockets from one manufacturer may not be interchangeable with others.
    The two you have linked to are totally different design, one will not properly fit onto a box from the other.
  5. JohnD
    JohnD
    15 Nov 2005
    74,268
    Thanks Received:
    4,290
    Crossgates, Europe
    Country:
    Cook Islands
    oi!
    I've got a living to make!
    • Thanks Thanks x 1
  6. andy11
    andy11
    19 Apr 2005
    1,787
    Thanks Received:
    204
    Country:
    Ones from different makes never fit each other!
    Don't be a cheapskate, buy the socket and back box combo, they are easy enough to fit.
  7. bennyboy1985
    bennyboy1985
    28 Jul 2014
    2
    Thanks Received:
    Essex
    Country:
    All the sockets installed In my garage are MK ones, so nothing about being cheapskate. I just wanted to know if I could install a different socket front of the same size from the same manufacturer. Seeing as I don't need to replace the back box I just wanted to know if I could replace the front on its own.
    Admin might as well close this thread.
  8. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    You can.
    You can.
    They could.
    Plan B is that if you wanted to install a different socket front of the same size from the same manufacturer you could ask about installing a different socket front of the same size from the same manufacturer (MK) and not one from a different manufacturer, as then you wouldn't get people telling you that you can't ;)
  9. Sponsored Links
  10. 333rocky333
    333rocky333
    12 Jan 2008
    8,426
    Thanks Received:
    902
    Essex
    Country:
  11. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    So your suggestion to a man who has MK metalclad sockets and back boxes is that he buys new sockets which don't come with boxes and bin the boxes he has?
    What does he then do with the sockets for which he no longer has boxes, as he has binned them?
  12. 333rocky333
    333rocky333
    12 Jan 2008
    8,426
    Thanks Received:
    902
    Essex
    Country:
    Most of the mk metalclad range come with a box so maybe i wrongly assumed the usb ones also do.
    Then again, if they do come with a box, rather than waste the new boxes he can pair them up with his removed frontplates for stock.
  13. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,782
    Thanks Received:
    2,858
    London
    Country:
    [​IMG]
    • Thanks Thanks x 1
  14. Lectrician
    Lectrician
    18 Jul 2004
    8,506
    Thanks Received:
    405
    Devon
    Country:
    The great thing with the MK metal clad is that you can bin the back box and fit the front to a flushed back box. Other makes you cannot. That said, when I do larger projects with loads of flushed metal clad fronts (pubs, clubs etc - bullet proof), the price for MK metal clad fronts less the back box is more than getting them off the shelf with a back box. Wholesaler pricing, not SF. I end up with loads of boxes at the end of the job, and they are pretty worthless. Skipable.
  15. phatboy
    phatboy
    22 Jan 2012
    2,194
    Thanks Received:
    259
    Jersey
    Country:
    For the cost of those, I would just plug in a USB charger TBH. I love things to be done the right way, but I would draw the line at a £30+ socket
  16. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
