I have a Miele WT945 washer dryer, I have two issues with the machine, first is that the shock absorbers need replacing.. which does not look too hard but will take some time and effort to replace. I can get some replacement ones off ebay for £20-30 i doubt they will be genuine miele ones but are meant to be compatible and I have looked at how I can replace them myself.
I have another issue with it which I require assistance with, when washing around the rinse part of the cycle the "water inlet/drain light" flashes red. The wash completes without any issues, there is no water left in the machine and it drains fine. There is a bit of a bad smell/drain smell that comes out of machine during part of the cycle when draining I think. I have undone the pump/filter at the bottom front of the machine, unscrewed it and it is not blocked. What else should I/do I need to look at?
Also is it worth fixing this machine now or is it time to replace with a newer machine - I would replace it with just a standard washer only around £400 mark, i only do about one load of washing a week and never use the dryer function?
Thanks in advance
Thanks in advance
