    Dismiss Notice
Mild corrosion on a circuit board
Discussion in 'Electrics UK' started by phatboy, 16 Oct 2020.
  1. phatboy
    phatboy
    22 Jan 2012
    2,150
    Thanks Received:
    251
    Jersey
    Country:
    Hi all,
    Due to a minor leak (Now resolved), there is a bit of mild corrosion on a circuit board in my mechanical heat recovery unit.
    I've read about how to clean it with deionised water, but as it is minor, is it even worth doing? If the source of the water has now gone, will it continue to corrode and lead to issues, or remain as is?
    Thanks!
  2. Sponsored Links
  3. JohnW2
    JohnW2
    28 Jan 2011
    47,649
    Thanks Received:
    3,101
    Buckinghamshire
    Country:
    Opinions will probably vary. Whilst it is quite probable that, if it now remains dry, no further deterioration will occur, for reasons you suggest it's possible that some potentially corrosive residues (from the leaked water) may still be present, and may eventually do some harm, so it might be wise to give it a little 'wash'.
    Kind Regards, John
  4. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,165
    Thanks Received:
    845
    Durham
    Country:
    Alcohol used to be the weapon of choice for cleaning circuit boards...
  5. Adam_151
    Adam_151
    17 Jun 2004
    6,670
    Thanks Received:
    274
    Country:
    Have you seen the Price of IPA recently?! :p
  6. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,165
    Thanks Received:
    845
    Durham
    Country:
    Well yes but its not so bad if you get it through Jeff's tat bazaar :)
    • Like Like x 1
  7. JohnW2
    JohnW2
    28 Jan 2011
    47,649
    Thanks Received:
    3,101
    Buckinghamshire
    Country:
    Is not IPA for wimps? - don't the serious drinkers drink meths or surgical spirit, either of which is very cheap (and very toxic!) but ideal for cleaning PCBs :)
    Kind Regards, John
  8. oldbutnotdead
    oldbutnotdead
    11 Jan 2013
    4,165
    Thanks Received:
    845
    Durham
    Country:
    Meths & surgical spirits both leave residues behind, as well as smelling lovely (not tried drinking them)...preferred burning surgical spirit in my old Mamod steam engine :)
  9. JohnW2
    JohnW2
    28 Jan 2011
    47,649
    Thanks Received:
    3,101
    Buckinghamshire
    Country:
    they do to some extent, but I very much doubt that they are the sort of residues which would ever do any harm to a PCB ... but goodness knows what IPA would leave behind :)
    I quite like the smell of meths, but not so much the other one - but I certainly would not advise drinking either of them!
    Kind Regards, John
  10. Sponsored Links
  11. mattylad
    mattylad
    27 Apr 2008
    7,986
    Thanks Received:
    595
    Country:
    Unfortunately John, even though it has dried it still needs cleaning off, microscopic dendrites can still form and cause issues - @phatboy - what was it that leaked onto it??
    If you do use IPA then keep it away from anything made of plastic and that may be some of the components/connectors (although they should be able to withstand a little cleaning).
    If no IPA then use deionized water as you suggest - but ensure it is left to dry thoroughly before powering up - using a hairdryer can assist with this.
  12. I wouldn't advise using Indian pale ale for cleaning it'll leave a sticky residue. :LOL:
  13. bernardgreen
    bernardgreen
    3 Nov 2006
    25,161
    Thanks Received:
    2,491
    Bedfordshire
    Country:
    The amount of damage to the PCB will depend on whether the unit was powered at the time the PCB got wet and whether there were any chemicals dissolved in the water.
    If there are any safety critical functions then ensure the PCB performs these correctly, otherwise a new PCB should be fitted
    If it was not powered then a good clean and effective frying should return it to normal functionality. Some PCB material will absorb water and this can require several days of gentle warmth to fully dry the PCB. Avoid excessive heat as some components will be damaged by heat.
    Putting the damp PCB into a bag with a desiccant such as dry silica gel while gently warming can be effective, from time to time drying the silica gel in a hot oven.
    If the board was powered when wet then
    creating connections between bits that should not be connected together are a definite possibility. They can be very difficult to find and remove.
    Even if the board "cleans up" visually there is always the possibility of components having being damaged by current flowing through the water and affecting the internals of the integrated circuits and similar components.
    one litre of Isopropyl Alcohol for £16 ( inc VAT ) from RS
  14. davelx
    davelx
    26 Sep 2006
    1,876
    Thanks Received:
    163
    London
    Country:
  15. boringoldcodger
    boringoldcodger
    1 Sep 2014
    113
    Thanks Received:
    23
    London
    Country:
    Just living down to my moniker:
    I'm absolutely certain Bernard meant "drying" ( d & f next to each other on keyboard).
  16. phatboy
    phatboy
    22 Jan 2012
    2,150
    Thanks Received:
    251
    Jersey
    Country:
    Thanks all for the replies,
    It's a low voltage board, it's the control board for a Heat Recovery Ventilation unit - https://www.vent-axia.com/range/sentinel-kinetic-bh
    It was powered on at the time.... I noticed as the fans were spinning up and down unusually, and the wired remote was showing garbled errors. I initially power cycled it, and all went back to normal, but it had reset to factory... even the hours in service was 0, but then went to the loft and removed the front cover, and below this PCB was a few drips of water.... basically the moisture should go down a tube that had become a bit gunked up (Despite recent servicing by me).
    Ill try the IPA gently... it looks to be a simple circuit board. There are some new ones on ebay for £100 - £250!
Loading...
Share This Page
