Mitusbishi Carisma '99 - Clutch problems
21 Dec 2014
Hi there!
I had a problem with my clutch, removed the transmission and need to replace the throw bearing, but it might have caused some damage (see pictures, you'll see one of the arms on it is bent), could you please tell me if i need to replace this or will it be ok? Would i be able to bend it back without problems? It's an old car and not worth much, so i'd rather not spend to much on it.
Thanks!
That will cause a juddery clutch mate......as you are so far in, replace the friction and pressure plate as well as the release bearing.
That damaged finger may cause the clutch to not release properly - the traditional crunch as you engage reverse!
John :)
