Moving the main supply cable
The fuse was at least 200 amps which meant about 50 kW of heat being generated in the arc at the end of the cable
More, I expect - don't know what type of fuse it was, but looking at Table 3A3(a) a 200A BS88 will pass 4-500A for 10 minutes.
And a stick of dynamite contains just under 0.3kWh. :mrgreen:
I'm not electrician and this could be extremely dangerous and so im in no way advising that this is done.....
But as I see it.... Would it be safe to disconnect the tails whilst everything else is still connected. Then unscrewing the wooden board from the wall, moving everything in place and then getting the electrician to also move the CU and extend any cables.....?
Not something you should ever consider on a PILC supply cable.
Sounds grim. My electrician must have known what he was looking at. Our cable was an overhead feed and looked more like the SWA I have running down the garden fence.
