    Dismiss Notice
Multiple switches from a fused spur
Discussion in 'Electrics UK' started by Jitno123, 18 Apr 2018.
  1. Jitno123
    Jitno123
    29 Jan 2017
    41
    Thanks Received:
    Country:
    Quick electrical question
    I currently have a floodlight outside wired into a fused spur which has been taken from a socket many years ago. I've recently had two more flood lights added (mrs not me!!), everything on LED so not an issue with load. When the builder put the lights up he ran separate cables back to this fused spur and has left it to the electrician to sort out. My question is; Is it possible to have a 3 gang switch from the fused spur? If so how is this done? As i dont want to run all 3 simultaneously.
    Thanks a lot
  2. JohnW2
    JohnW2
    28 Jan 2011
    42,526
    Thanks Received:
    2,697
    Buckinghamshire
    Country:
    Yes.
    Essentially in exactly the same way as if there were three separate switches. The electrician will have no problem doing that.
    Kind Regards, John
  3. Sponsored Links
  4. securespark
    securespark
    11 Jan 2004
    33,621
    Thanks Received:
    1,022
    Country:
    When he comes back off holiday!
    • Like Like x 1
  5. yorkspark
    yorkspark
    6 Mar 2011
    144
    Thanks Received:
    25
    Yorkshire
    Country:
    Should of thought of that before you got a “builder” to do an electricians job! This is a simple task for a competent sparky
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
