My Complete DIY Rewire
Status
Not open for further replies.
Agreed. However, I presume that 'they' (and probably many/most of us) also believe that there is no pressing need (certainly not any evidence-based need of which I am aware) to not allow ring finals to continue to be installed.
If you believe that they would not be allowed were they to be considered as a new invention, subject to sound engineering judgement, then logic and reason should lead you to believe they should be phased out.
You could argue that - but, as I said, that essentially logical argument does not indicate that there is necessarily a 'pressing need' to phase them out.
Don't forget that, unless there were all sorts of changes in the rules, your proposal would presumably result, throughout a period of several decades, millions of EICRs (or whatever they may come to be called in times to come!) 'coding' the presence of (no longer compliant) ring finals.
Kind Regards, John
BASARFBan All Sheds And Ring Finals Yawn
Quite. He's effectively said that he doesn't see any point in his making representations about this to JPEL/64 when the next BS7671 DPC comes along, so I really don't see what he thinks will be achieved by his going on about, time after time, it here! Maybe he feels that if he repeats his view enough times here, it will somehow influence 'them':)
Kind Regards, John
Not sure I said I won't.
But I don't believe there is any point anybody making such representations because I don't believe that any, or enough, people on JPEL/64 have the ability to think clearly.
You go on about, time after time, espousing your position. Why?
Of course it does. Logic is all that's necessary. If logic says phase them out then there becomes a pressing need, because the regulations should be based on logic, not on an irrational desire to maintain a practice which has outlived its purpose and which would fail any engineering test were it to be considered as a new invention.
So would you have used that principle to argue against such changes as no longer allowing lighting circuits with no cpc, no longer allowing sockets with no RCD, no longer allowing concealed cables with no RCD, and probably any number of other changes to the regulations which made something installed "yesterday" no longer compliant with "today's" regulations?
Not sure I said I won't. But I don't believe there is any point anybody making such representations because I don't believe that any, or enough, people on JPEL/64 have the ability to think clearly.
As you correctly quote I did not say that you "won't", but rather that you didn't see the point - which is precisely what you've just said again.
So my point remains. If (and I'm inclined to agree) you don't see any point in presenting your argument, even once, to JPEL/64, I'm not clear as to what point you see in repeatedly presenting the argument here - it's not as if we do not know what your view is!
Kind Regards, John
Is it not more a case of the writers of BS7671 do not have the power or authority to ban ring circuits?
All they can do, which they do do, is state rules to ensure safety.
We are free to design any circuit as long as it can be proved that it is not unsafe.
It can hardly be argued after all this time that rings are unsafe.
It would surely require legislation to actually ban them.
Of course it does. Logic is all that's necessary. If logic says phase them out then there becomes a pressing need ....
That's a very theoretical, almost philosophical, general argument. I would imagine that 'they' would only see a 'pressing need' if they perceived a clear (not just theoretical) safety issue - which I don't think there is.
No - because, as above, all those changed did result from perceived significant safety issues, and therefore were deemed to have 'pressing need', outweighing any considerations of 'inconvenience'.
Kind Regards, John
Is it not more a case of the writers of BS7671 do not have the power or authority to ban ring circuits? All they can do, which they do do, is state rules to ensure safety.
Indeed - but (playing Devil's Advocate) there is no need for them to allow a situation which carries a finite probability that cables will sometimes be overloaded in a manner that they would not allow in any other situation/context.
We are free to design any circuit as long as it can be proved that it is not unsafe. It can hardly be argued after all this time that rings are unsafe.
Still playing DA, it depends upon what you mean by 'unsafe'. BAS's argument is that in any other context (in which overload protection was required) they would not allow a situation in which current in a cable could exceed its Iz (or, more precisely, if current could exceed more that 1.45Iz for an hour), even if that was only going to be a fairly rare occurrence - presumably on the basis that they consider that to be 'unsafe'.
I think you're getting unnecessarily 'technical' here. Nothing in BS7671 is mandatory - when people talking of 'banning' (ring finals), I think they mean 'making them non-compliant with BS7671', not making them automatically unlawful!
Kind Regards, John
I did not gratuitously raise the topic, every post I have made (apart from the first) has been in response to someone mistakenly claiming that ring finals are good, or should be allowed to carry on.
It's one which relates to what should be a vital foundation of technical regulations.
I wonder what the clear, evidential, safety justification was for the introduction of Cmin?
Be that as it may, chaos did not result when EICRs started recording "does not comply" for features which had complied before.
That was my point.
How could a non-statutory body ban something (by making it non-compliant) that has been compliant for over sixty years without something having happened, other than thought, to change the status quo.
For instance, could they suddenly decide that the minimum CCC shall be 32A (or 28A)?
I'm not suggesting otherwise, but you don't really need to burden yourself with repeating things you've written so many times before - don't you consider simply providing links to previous threads, thereby saving yourself time and effort?
Kind Regards, John
Well, many things which have 'become non-compliant' have been 'compliant' for a long time before that happened. As you know I don't personally believe that our experience of many decades of using ring finals affords any evidence (of which I am aware) of a need to make them non-compliant. However, in some situations, the 'reason' is primarily one of thought/theory, rather than 'evidence'. The requirement for RCDs in some situations first appeared on a 'theoretical' basis, before there was any real actual 'evidence' of a benefit, let alone 'need'. I doubt that the requirement for CPCs on lighting circuits resulted from evidence of people being electrocuted by metal fittings - rather, it was probably introduced on the basis of theory/thought ... etc. etc.
They 'could' obviously do anything they wanted. Assuming you're talking about ring finals, 32A would be silly, because it would effectively remove the need for 433.1.24 at all (other, perhaps, from pointing out that there was no objection to the end of a sockets circuit being returned to the CU). 28A would also essentially kill ring finals as we know them, since they would have to be wired in 4mm² cable, so might just as well be done as 32A radials (maybe saving a bit of cable).
Kind Regards, John
Status
