You could argue that - but, as I said, that essentially logical argument does not indicate that there is necessarily a 'pressing need' to phase them out.If you believe that they would not be allowed were they to be considered as a new invention, subject to sound engineering judgement, then logic and reason should lead you to believe they should be phased out.Agreed. However, I presume that 'they' (and probably many/most of us) also believe that there is no pressing need (certainly not any evidence-based need of which I am aware) to not allow ring finals to continue to be installed.
Don't forget that, unless there were all sorts of changes in the rules, your proposal would presumably result, throughout a period of several decades, millions of EICRs (or whatever they may come to be called in times to come!) 'coding' the presence of (no longer compliant) ring finals.
