eeek it's nearly Christmas and we are hopefully going to semi move in this weekend! This update it just about the rendering. So we went with a local chap who just does k rend thin coat systems. I did some digging before and concluded although there are less well known products which are probably better than k rend finding anyone with experiance in using them is not easy. For that reason along with meeting the area rep for k rend (nice guy) we decided to go with it.
The chap we chose gave us the option of externally insulating the house. It came with a few plus sides. Firstly we didn't need expansion joints between the old and new parts of the house and meant cracking was less likely. Secondly With the thin coat it is also easier to repair than the normal k rend so if we do have any cracks it is possible to fix it without redoing the whole side of the house. Thirdly some of the blocks which were used to build the house had what appeared to be rust spots. Apparently these will eventually show through the render but obviously by having the insulation it will prevent this. Lastly it will make the house more energy efficient. It was only around an extra £2k so we decided to go with it and are really happy we did.
The only issue we did have with the render is it seems to be a bit hit and miss as to how long it takes to dry. Unfortunately our house being not far from the sea does have a side which takes a bit of battering. This lead to the side being ruined before it had time to set. Fortunately the guy we used was very good about it and re did the whole side again for us.
Anyway onto some pictures.
