My new Oven!!
7 Mar 2006
Staffordshire
Hi!
I know this appears to be going over old ground, but i need to satisfy myself of the position.
I have recently purchased an electrolux fitted oven with a power rating of 3,000 W.
My electrician assures me that this can safely be connected to my downstairs ringmain via a standard socket and 13 amp plug and will work quite happily and safely
Can anyone re-assure me that this is indeed the case?
(FYI, the hob is gas and all other large itemns such as tumble dirie/ washer etc are wired to a different ring main)
3000W divided by nominal 230V = 13 A (divided by actual 240V = 12.5 A)
Of course it's okay, they're designed that way and often come supplied with a moulded 13A plug.
Why did you doubt your electrician?
Just after some re-assurance as i had not come across this before. In addition the booklet (whilst refering to 13 amp sockets etc) also referred to an option for a cooker control curcuit and the need for a double pole switch. Why would this be stated if it can just be pugged in and switched on?
Also would a fused switched spur be a better bet than a simple socket and plug?
A FCU is not as deep as a plug and socket so if it's behind the cooker this an be an advantage. A plug is better for maintenance. Pro's and con's for both. If you have a plug and socket and your happy, why spend money on a FCU?
FCU is better because it lacks the weak point of removable contacts. Remember, 3KW is absolute max. for a 13A plug, and it will get warm due to resistance on the plug's contacts. I would install an FCU.
It can just be plugged in, but if it is not too difficult it would be preferable to install a dedicated 16A radial circuit for it
Bernie1976 said:
Hi!
After reading your post again, you may want to check what else is on the ring circuit as it must also do the rest of the kitchen. If you have a freezer, dishwasher, tumble dryer, washing machine, then a new circuit maybe required
The only other draws on the circuit would be downstairs sockets e.g. just tv etc and with regard to kitchen appliances there would be just a small fridge and then the kettle etc. Larger appliances such as washer/ drier etc are on a separate circuit.
I take it that this should mean a standard socket and plug (although not supplied with appliance) should be fine?
